 GMC counter MQTT/Home Assisant integration
Author  Topic Next Topic
serial_reset
Posted - 04/03/2025 :  12:44:51  Show Profile  Reply with Quote
For those interested, I publised this article (in French) about MQTT/Home Assistant integration of GMC hardware:
https://forum.hacf.fr/t/tuto-integration-compteur-geiger-gmc-dans-mqtt-et-home-assistant/60789
Kind regards,
serial_reset
RedTiger
Posted - 08/02/2025 :  02:25:32  Show Profile  Reply with Quote
i wasn't successful by directly integrating GMC in HASS.
But i was successful by integrating it, by having it connected to a machine running "GeigerLog".
Over this i was able to get the data from the local GeigerLog Monitor Server. By using the Monitor Server provided data-feed "lastdata" i was able to do the necessary Sensors in yaml configuration:
sensor:
  - platform: rest
    resource: h**p://IPofYourGeigerLogServer:8080/lastdata
    method: GET
    scan_interval: 30
    unique_id: raw_data
    value_template: "{{ value }}"
  - platform: template
    sensors:
      cpm:
        friendly_name: "CPM"
        unique_id: cpm
        unit_of_measurement: "CPM"
        value_template: >-
          {{ states('sensor.raw_data').split(',')[1] | int(0) }}
      usvh:
        friendly_name: "µSv/h"
        unique_id: usvh
        unit_of_measurement: "µSv/h"
        value_template: >-
          {% set cpm = states('sensor.raw_data').split(',')[1] | float(0) %}
          {{ (cpm / 151.5) | round(2) }}
Maybe that helps someone. Didn't found it out of the box anywhere.
Edited by - RedTiger on 08/02/2025 02:40:10
   Topic Next Topic
