 What is good position of emf 390 to check EF
DoOm Posted - 07/02/2020 : 05:24:30
Hi
I have just bought GQ EMF 390 v2. and have some problem.
How to use and point it towards EF(Electric field). The level of EF is changing dramatically in terms of position of this meter. Axis Y is towards ceiling or window. like on the picture 1.
The problem is, if the device is put in diffrent poitions shows different measurement, so the question is what position is good?
On picture below is example of reads towards wall where are 3 sockets and wires.
Thx for an answer because I am confused now.
A one more what means MIxed EF, Power Line EF and AC EF.
Mixed EF means nothing wrong or I should be worried?
EmfDev Posted - 07/02/2020 : 10:08:50
Hi DoOm,
I believe those are static EF. The static EF basically is static electricity, it exist almost anywhere which may not need to be worried in cases of high reading. It always changes from one object to another. Many cases can have high static electricity in our daily life. For Example, when you take off your wool clothes, it may generate more than a 1000V static electricity. Also, Human body has electrostatic discharge (ESD, the sudden flow of electricity between two electrically charged objects caused by contact, an electrical short or dielectric breakdown). This impacts the EF reading too.
If your meter’s possible source showing “AC EF” and reading higher than 50V, then you may need to care about it. Otherwise you may not have to worry, the meter just telling you there are static EF around you.
The EF only has one direction and should pointed at the object and the position is close the the top left of the sensor.
The Mixed EF means that the unit have detected other sources like cell phone RF or other EMF's. But mostly the EF is static in that case.
