 GMC-600 dead after runnung out of battery
Hoang Vuong Posted - 10/01/2018 : 00:35:38
what a *BAD* surprise. After running out of battery my GMC-600 is charging to 100% but it is not reacting to anything.
What should I do?
TIA
Gottfried
EmfDev Posted - 10/01/2018 : 08:50:12
Hi Hoang, have you tried charging it for few minutes?
When charging, it doesn't turn on when you long press the power button?
It probably isn't 100% so try to charge it for a while.
If possible, check the battery voltage with a multimeter to confirm
if it's battery problem or charging.
Was it charging before it ran out of battery?
