 Sensor location EMF-380
n8xyn Posted - 05/03/2018 : 18:33:47
Exactly where are the sensors located in the EMF-380 so I know the best way to hold the unit for the best accuracy?
priotok Posted - 02/08/2022 : 13:43:19
All antennas are oriented on the rear side of the device. Great location accuracy is not important.
Broadband antenna up to 10 GHz and magnetic field antennas
priotok Posted - 02/08/2022 : 13:30:08
Band Antennas 76-108MHz, 2.4-2.5GHz, 50-76MHz/300-928MHz
Electro Posted - 12/20/2021 : 08:43:39
@EmfDev
Hello ! I drew something related to what you said, to make sure I really understand well. In the manual of EMF-390 revision 1.90 page 7 it's written:
Hold and position the meter
To get as accurate reading as possible, always point the
meter front (sensors) side to the source.
(Y direction is preferable)
QUESTION 1: The front sensor side in the manual, is it the back, the top of the face from my own images?
QUESTION 2: Can you validate that my drawing is right, especially the directions of X,Y,Z?
QUESTION 3: On any given situation, should I hold the meter in a laying position like Image C or in an upright position like A-B ?
Upright position = The top facing the sky
Laying position = The top facing a person in front of me.
Thanks.
EmfDev Posted - 05/24/2021 : 13:19:45
Hi ellie, the X, Y, and Z sensors are for EMF and they are cylindrical in shape. The X points toward/away from the buttons/screen. Y points sideways, and Z points up/down. The EF sensor is rectangular in shape and is flat and the orientation is also sideways but is perpendicular to direction of screen).
ellie Posted - 05/21/2021 : 19:21:27
Regarding orientation, can someone please better explain the meaning of the red squares showing X Y Z, I am a bit confused.
If I am specifically looking for EF, it says I would want to use the Y direction. What position should I hold the meter in, and with what side/edge should face the item I am checking?
igel Posted - 04/06/2020 : 10:48:20
There are different sensors for the spectrum analyzer.
70917 bytes
EmfDev Posted - 10/09/2018 : 09:00:31
The EF should pick up with same direction as the X, Y, and Z. However Y direction is preferable.
robeyw Posted - 10/06/2018 : 01:23:05
Please describe the RF sensor. I assume that at low and mid frequencies it only picks up the electric field component normal to the face of the instrument and judging by the size I think it could be true for the highest frequency as well. Is this sensor used for all the ranges of the spectrum analyzer?
n8xyn Posted - 05/05/2018 : 11:43:18
Thank you very much :-)
ZLM Posted - 05/05/2018 : 09:43:27
EMF-360,EMF-380 sensor location:
187026 bytes
