 Map not showing after login
Nisei Posted - 12/04/2015 : 01:45:25
When I go to GMCmap (Firefox 42.0) I can see the map. But when I log in and return to the map it's gone and I can only see the table with country flags. Please fix this.
Peety Posted - 07/15/2017 : 09:37:55
It is the same problem in every browser, also in Internet Explorer.
Originally posted by JKato
No map after logging in. I recently created an account and I noticed that the map size under my account information was blank. This information is not asked in the original "New Account Registration" form.
Note that the form doesn't accept numbers over 999, so 1000 gets truncated to 100. The admin for this site should probably insert some default values here.
Please allow map sizes more than 999
1920x1080 or bigger
ZLM Posted - 06/11/2017 : 21:32:30
Make sure you entered Prefered Zoom.
JKato Posted - 05/21/2017 : 16:50:00
I think I figured out the problem.
I was having the same deal. No map after logging in. I recently created an account and I noticed that the map size under my account information was blank. This information is not asked in the original "New Account Registration" form.
I edited my account and put in a size for
"Max Width Pixels" 999
"Max height pixels" 800
and it works now. Note that the form doesn't accept numbers over 999, so 1000 gets truncated to 100. The admin for this site should probably insert some default values here.
you may also want to play with the zoom number. I have mine at 5.
ZLM Posted - 03/07/2017 : 23:48:52
What is your web browser version? I am just trying to repeat the problem.
housinit Posted - 03/06/2017 : 14:34:48
I seem to have this problem more often than not. Exact same issue others have. Page loads with links and flags from the page footer, but no map......only happens if I am logged in. Once I logout I can see the map just fine.
ZLM Posted - 02/08/2016 : 21:06:23
it seems someone submitted garbage data.
Craignator Posted - 02/07/2016 : 08:09:45
Is there an issue with the page display? I get nothing but some links to refresh on the bottom of the map page, no map, just blank
Craignator Posted - 02/05/2016 : 14:33:18
Your not alone, I haven't seen the map for some time, today is the 5th of Febuary
ZLM Posted - 12/05/2015 : 20:23:22
fixed.
Nisei Posted - 12/05/2015 : 08:17:59
Today I can't see the map at all.
Not in Firefox, Chrome or Explorer.
140.56 KB
