 GCM-600+ Spike while on iPhone
kamilw Posted - 05/31/2019 : 08:44:06
Hi All,
My counter shows ~20-30 CPM at home, but once I place it on top of you iPhone and leave it there, it consistently goes up to 60-70 CPM.
Any insight why that is the case?
ortegaalfredo Posted - 06/15/2019 : 18:13:27
Just put my GCM-600+ on top of my phone (Samsung S9+) and called it 4 times.
Readings didnt increased notably. They went from 37 CPM to 45 CPM, all within normal variation. Just a datapoint.
stduser111 Posted - 06/04/2019 : 16:39:10
And EmfDev is eager to state that not only the GQ but "99% of household dosimeters" suffer from this problem. I would like to know which dosimeters belong to the remaining 1% category?
That was my comment. I do not remember the name of those models, but you will not find such a model among the cheap ones. If it is so important for you, then you can try to open the device and shield the PCB using aluminum foil.
But I do not think this is a big problem. It is very easy to distinguish ionizing radiation from electromagnetic interference.
ullix Posted - 06/04/2019 : 01:13:14
@kamilw: interesting observation. I tested my 300E+ counter by putting it on an Android smartphone. CPMs didn't change. However, when I started a phone call on this phone, and then put the counter on it, the CPMs increased from 20CPM to ~35CPM.
So it demonstrates that you have to well consider the environment of your counter. Some strange results may be explained by such interference!
EmfDev Posted - 06/03/2019 : 09:09:28
Hi kamilw, do you hear more click sounds as the cpm increases?
stduser111 Posted - 06/01/2019 : 17:04:25
Hi. This is normal. This is electromagnetic interference due to the fact that the processor is not shielded. 99% of household dosimeters on the market have such a problem. Just do not bring the dosimeter too close to powerful sources of non-ionizing electromagnetic radiation.
Generated in 0.23 sec. Snitz's Forums 2000
