 Need a step by step guide on GMC-600+ WIFI setup
Sonicmixmaster Posted - 05/15/2019 : 14:14:47
I have had the 600+ for almost a year and I am ready to try wireless reporting to GMCMap website. I do not want to leave it connected to a PC and use software for data collection and upload. I want to use WIFI as a way to upload data straight from my unit which I have sitting next to my computer. If I set up WIFI and it is successfully uploading to the map I will be able to monitor readings of outside right on my window. I would like to see if there is going to be and noticeable difference as the seasons change.
Thanks!
EmfDev Posted - 05/24/2019 : 08:45:34
After setting up those parameters, you need to turn on WiFi on the device. After turning on the WiFi, you need to do the Test Connection in the server menu and make sure it's successful. You can also set the period to control how often it sends data to online.
EmfDev Posted - 05/23/2019 : 15:14:21
On your 600+, you need to input WiFi user ID and password, and Geiger counter ID, and user ID in the server settings.
So need to input 4. You can use data viewer to update those parameters or you can also change in using the 600+.
EmfDev Posted - 05/23/2019 : 15:11:15
Have you already created an account?
Also you can use data viewer Settings->Other to input your ID's to the device.
Sonicmixmaster Posted - 05/23/2019 : 14:47:49
I need to know how to setup wifi uploading of data for my gmcmap account.
EmfDev Posted - 05/16/2019 : 08:25:21
Hi Sonicmixmaster, let us know if you encounter any problem. Good luck! I hope no one steals your geiger counter.
