 USB Driver verification
ZLM Posted - 07/18/2017 : 09:55:29
To check if the USB driver loaded correctly, you need to use Device manager of Windows.
See this:
53411 bytes
This picture shows the the USB driver has been loaded correctly and the comport is COM7.
[b]Further verify the USB device ID:/b]
120190 bytes
Timothy Love Posted - 11/09/2022 : 18:53:12
Very detailed
Goat212 Posted - 04/15/2022 : 08:10:10
Originally posted by mojo66
Note that on a Mac no driver installation is required, just start the app and connect the device.
In fact I haven't installed a single driver in decades of Mac usage.
What is the app you are using?
mojo66 Posted - 08/30/2021 : 18:01:59
Damien68 Posted - 01/30/2021 : 12:16:56
Originally posted by PilotDane
I too am unable to install the USB driver. I get the following error:
"Cannot create DRVSETUP64\DRVSETUP64.exe"
I check device manager and I have USB-Serial CH340 (COM3) and when I check the details, Hardware Ids I have "USB\VID_1A86&PID_7523&REV_0264" and "USB\VID_1A86&PID_7523".
If you have COM3 present in device manager with right VID/PID, the driver is already installed and good.
VID/PID is VendorID/ProductID, is what windows use to attach a specific driver to a specific device.
ihab17 Posted - 01/30/2021 : 11:30:55
You may need to download the driver from Microsoft. It is a cab file, extract it to a folder then update the driver pointing to that folder
h**p://download.windowsupdate.com/d/msdownload/update/driver/drvs/2016/07/20712561_da2389de3e27b0ca87312a0e8d187be11de354c3.cab
Otherwise download the driver from the original Chinese manufacturer here
h**p://wch-ic.com/products/CH9340.html
PilotDane Posted - 01/30/2021 : 04:51:34
EmfDev Posted - 08/20/2018 : 15:39:53
Hi Lollttie, you can contact/email support@gqelectronicsllc.com for better assistance.
ZLM Posted - 07/24/2018 : 09:53:36
In stall the USB driver first:
http://www.gqelectronicsllc.com/downloads/download.asp?DownloadID=78
RDCWizard Posted - 02/19/2018 : 11:04:55
Windows 10 Pro Insider Preview Evaluation Copy Build 17093 does not have Serial Ports. Unable to connect my GMC320 Plus to the computer not matter what I do. Help anyone? tks.
