 What tubes are in the GMC+500+
n8xyn Posted - 04/13/2018 : 10:35:11
I just want to research them
ullix Posted - 04/20/2018 : 23:58:29
@Distel: You are right. I should have worded it the other way round: instead of creating a new device with a perhaps 2fold lower sensitivity, GQ could just as well have fixed their flawed firmware and gained a factor of 2 just by that!
If you want to reduce sensitivity of your counter, put it into a metal (iron, lead) enclosure.
And lastly, as a user of these products you better make sure never to get into a situation where you'd need the high count rate sensitivity. Run the other way, then.
Distelzombie Posted - 04/18/2018 : 04:36:39
"The SI3BG tube is suitable for use with powerful radiation sources or for severe nuclear incidents resulting in high radiation doses."
This is all the more ridiculous, as the GMC processor and software at least is the 300series is not even capable of handling the counts possible with the M4011 tube. http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=4613&SearchTerms=ullix,overflow
Why? It makes perfect sense. It not a more sensitive tube. It is less sensitive = less cpm per ySv
ullix Posted - 04/16/2018 : 05:59:56
@Jim: I'd be surprised if there is one. The tube sensitivity is first proportional to their inner volume, and second to their inner surface. For a given volume a more slender tube is more sensitive than a thicker one.
The SBM20 tube is a little bit longer than the M4011 at about the same diameter, and comes with a 40% improvement. It almost fits as a direct replacement, but you'd have to relocate one of the two tube holders. A comparison of the two here: http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=4571&SearchTerms=ullix,sbm20 But note the caveat: probably valid only for a beta-source. The effect on gammas is not known.
In fact, the closeness of the calibration factors between the SBM20 and the M4011 (the latter as reported by GQ) suggests that the expectation is that the two tubes basically are the same, see here http://www.gqelectronicsllc.com/forum/topic.asp?TOPIC_ID=4578
The size relationship to sensitivity is further corroborated with the choice of the tiny (!) tube SI-3BG as the second tube in a 500+ counter. This website with pictures says: https://www.pocketmagic.net/tube-si-3bg-c%D0%B8-3%D0%B1%D0%B3-small-geiger-muller/
The SI3BG tube is suitable for use with powerful radiation sources or for severe nuclear incidents resulting in high radiation doses. It makes no sense to use it for your DIY experiments, as the background radiation CPM on this tube is close to 0:
n8xyn Posted - 04/15/2018 : 15:01:33
Is there a more sensitive replacement for the M4011 that is a direct fit?
the_mike Posted - 04/15/2018 : 05:22:21
@Distelzombie
the 500 is using just an M4011,
the 500+ (@n8xyn) is additionally using an SI3BG for higher ratings - it's described in one of the 500-threads, i think the info slipped unintentionally ;)
(unfortunatly, it's not possible to just "retrofit" an SI3BG into a 500 eventough the socket is there - the + is using another firmware)
Distelzombie Posted - 04/14/2018 : 13:32:58
Doesn't it say that in the technical description of it from sellers?
It should just be the M4011. Or two. I don't think they used a different one for it. It's a cheapy.
