 Desoldering gun compatible with GQ5200
rddube Posted - 07/31/2015 : 03:07:16
Is there a desoldering gun compatible with the GQ5200?
Thank you!
Betty Hunt Posted - 05/17/2019 : 03:02:03
Even you can also check the new portable vacuum suction desoldering gun on Amazon.
radciffkaty1 Posted - 04/08/2018 : 23:41:57
Yes, @ZML said correct but if you still want to go for desoldering gun then you should try "Hakko FR300-05/P Desoldering Tool" available at Amazon and many other sites.
ZLM Posted - 08/01/2015 : 17:05:33
you do not need a desoldering gun is you have GQ5200.
The hot air gun is much better for any desoldering gun.
