 GQ Geiger Muller Counter
 sudden jumps in CPM
mgcdenmark Posted - 05/26/2016 : 11:12:55
Hi there.
I just bought the GMC-300E Plus Geiger.
It reads CPM aorund 12-20 - which i guess is normal. but 3 times during the afternoon it jumps up to appr. 200 and the alarm sounds.
Do you know why this happens ?- It falls down to normal level after 2 minuttes or so.
I have not calibrated the detector - should i do that ?
wd9dui Posted - 09/17/2017 : 12:33:09
Well just received my new GMC-320 Plus, my life has gone back to normal, no more shy high readings!
wd9dui Posted - 09/13/2017 : 09:59:03
I have a GMC-300E FW 3.10, since 2012, it has just stated to go way off on readings, up to 1500 CPM at times and will go high through out the day off and on, this all started a week ago. After doing some reading it maybe the tube maybe needing replacement. I have made a decision just to replace the unit with an new 320 plus. Technology has change over the years and sometime the new stuff is better......
ZLM Posted - 05/26/2016 : 16:52:34
I think you may need to watch it for a longer period. If it happened again , then contact support@gqelectronicsllc.com.
Distelzombie Posted - 05/26/2016 : 14:09:57
Is someone carrying bright orange dishes around.
Generated in 0.05 sec. Snitz Forums 2000
