T O P I C R E V I E W |
drosen9 |
Posted - 07/07/2016 : 19:37:55 Hi, I have been observing that in New York City trees and other plants seem to be 'withering' and dying. If you look at trees that used to have full foliage the leaves are small, bent up cuplike, branches are going bare; I suspect its from UV-B solar radiation and its very widespread.
Does anyone know what nuclear radiation's effect on plants would be like? Thank you,
4 L A T E S T R E P L I E S (Newest First) |
GBG12 |
Posted - 06/29/2017 : 18:41:35 I think all the recent release events have been small. Detectors have mostly been deployed after the big releases, and often by government agencies that don't always put transparency first. That is why more and more private detectors are joining real-time map sites. The GM tube detectors made by GQ and others are sensitive enough to detect many events. Real-time sites like Radmon.org and Netc.com, as well as this site, show how some users test their detectors with radioactive sources. I use Uranium glass beads to test mine. For a proof of sensitivity to real events, Safecast.org has a map showing mobile GM detector trails past actual hot sites including Chernobyl, Fukushima and Uranium mines. On that map, even altitude-related increases can be seen. |
ChrisLX200 |
Posted - 06/29/2017 : 14:37:07 Seems curious to me that even with all the reactor disasters in the world over the past few years not one of the detectors displayed on the map shows anything other than perfectly normal background levels - yet we know plenty of nucleotides have been released into the environment. So is it a question of low sensitivity of the detectors? If so, what is the value of these detectors anyway?
GBG12 |
Posted - 06/19/2017 : 18:30:47 Nuclear radiation can be harmful for sure. UV radiation less so, but it does have an effect. It was studied when the ozone hole was growing, but thankfully some smart scientists worked out the reason and it's not growing so fast now. Here is an article on UVB and plants: www.uv4plants.org/wp-content/uploads/2014/10/UV-web-opt.pdf |
esquehill |
Posted - 06/19/2017 : 15:49:05 https://en.wikipedia.org/wiki/Red_Forest |
