 GQ-5200 schematic
rddube Posted - 09/19/2015 : 01:55:40
Hi, do you have the GQ-5200 schematic that you could post? In English if possible?
Thank you.
NealXu Posted - 01/17/2018 : 09:47:08
Hi...this looks like a better unit than the KADA 952D+, I cannot recommend the KADA to anyone, just too many flaws, and they've been repeating those same flaws for over 4 years, they are oblivious to QC and oblivious to improving their product.Yours has an IEC socket, much better implementation: can you check the fuse value?
More modern board with *C and *F selectionYour transformer is mounted better and has identification on it.Yours has more meaningful panel function identification, the KADA uses A and B to identify the heater which is daft.
https://www.7pcb.com/
ZLM Posted - 01/19/2016 : 14:41:15
[b]Image Insert:[/b][br][br][size=1] 88793 bytes[/size=1]
rddube Posted - 11/24/2015 : 04:27:13
Hi ZLM,
Is the rest of the schematic available? When will it be posted?
Thank you,
Raymond
ZLM Posted - 10/01/2015 : 07:30:35
Not in full.
Main circuit:
79.18 KB
MCU and display:
62.73 KB
Generated in 0.14 sec. Snitz Forums 2000
