 Old 115VAC wiring w/no GND = High V/m readings?
Lauerkj Posted - 01/14/2021 : 20:07:58
I have two bedrooms with very similar arrangement of wall plugs, night stands, lamps, etc. One has EF readings near the bed pillows of around 55V/m and the other has EF readings of around 5V/m near the bed pillows! Lamps and clocks are the same. Could it be that the lower EF bedroom is wired with 3 wire plugs (ground wire) and the higher EF room is wired with 2 wire plugs (no ground wire)? I rotated the EMF-390 meter and the above readings are the highest identified for both locations.
EmfDev Posted - 01/19/2021 : 15:12:41
Hi Lauerkj, those are mostly static EF from the lamp. The lamp has very high EF and can polarize objects around it. Grounding also is better. But <100V/m in static EF is not necessarily bad since they are mostly static.
