 OK.ERR0
philtong Posted - 12/15/2017 : 01:20:23
new GMC500 setup to map but not showing? all the connection tests ok, timer set to 2 minute intervals but not showing up. I get that message in the PRO S/W Data Submitted to Server OK.ERR0 I want to fix this and contribute to the world map! Any assistance is greatly appreciated!
Ok looks like there's two of us monitoring here (howzit Lightspeed). I showed up briefly. Now see Lightspeed's count on the green peg. As I zoom in/out the peg toggles from 18 to 2 and back to 18. I think the map is only displaying the highest count submitted at the time.
philtong Posted - 12/16/2017 : 13:38:40
roger. everything working now! we had a single alarm last night then back to normal. interesting to monitor :)
ZLM Posted - 12/15/2017 : 09:42:18
If you have two devices,then you need to assign two different Geiger counter ID on each. Otherwise the system only show the last data received,
Generated in 0.02 sec. Snitz's Forums 2000
