 floating warning mails
MeasureMan Posted - 08/19/2025 : 22:50:11
I got a fload of warning mails starting around 2 o clock due to a warning setting of cpm value of 1 I never set.
Furthermore a integer value for micro Sievert values is not an good idea to be warned.
Ponty Posted - 12/02/2025 : 09:26:28
I also started getting warnings on 30 cps some months ago.
Did anyone find out if someone added this to our profiles, or if it is something in the environment or device which has changed causing these measurements.
Momer Posted - 08/21/2025 : 06:37:27
I have also beginning this days receiving E-Mails with "High CPM from your device". I can fix this problem on the GMC website on my own user profile. The user profile there is a setting for set the private threshold. It was set to 30 CPM. exactly the value of the e-mail content.
