 Upload period 5 min or more for GC World Map
GTS Posted - 05/28/2024 : 17:23:12
My GMC 600+, SW 2.52, has the ability to change the WiFi data logging period from 1 minute to some larger number of minutes. But the GC World Map will default to 5 minutes or more regardless of what I set the 600+ at. (from 1 to 4 minutes). At 5 minutes and above, the uploads seem to be at the desired 600+ period.
Is this the "as designed" state of the Geiger Counter World Map?
What is going on here?
GTS Posted - 05/29/2024 : 15:48:44
Thanks for the answer EmfDev.
EmfDev Posted - 05/29/2024 : 11:29:13
Hi GTS, currently the server can only handle upload every 5 minutes. We are trying to improve it.
GTS Posted - 05/28/2024 : 21:49:40
OK, I figured it out using manual uploads. Only WiFi data uploads at least 5 minutes apart are displayed on the GC World Map and recorded in the history file. Uploads every minute seem to be taken by the server without upload errors but are not displayed on the map or in the history. Those uploads go off the edge of the cliff never to be seen again. Also tried with 6 minute uploads and those displayed and were recorded in the history file.
So the answer seems to be YES, this is currently how the "Geiger Counter World Map" works.
