T O P I C R E V I E W |
Flyjar |
Posted - 12/31/2021 : 07:34:11 Hi there,
I would like to connect my GMC-500+ to WiFi and then be able to view the readings over WiFi. However, I'd prefer to not use the World Map. Is there a way of hosting privately?
Thank you! |
ullix |
Posted - 01/11/2022 : 05:41:00 @EmfDev: I am afraid this won't work. Read my comment above carefully.
You have a bug in the firmware, which requires a workaround.
EmfDev |
Posted - 01/10/2022 : 12:14:50 Hi Flyjar, you can also do it by changing the parameters from the device website and URL. The device sends it as: GET /'URL'?AID='USER_ID'&GID='Geiger_Counter_ID'&CPM='CPM'&ACPM='ACPM'&uSv='uSv' HTTP/1.1 Host: 'WEBSITE' Connection: close Accept: */*
ullix |
Posted - 01/01/2022 : 01:37:11 It is possible with a bit of a hack.
The upcoming version of GeigerLog will offer a way to establish a redirection of the 500+ counter data into GeigerLog. Problem is that the 500+ has a flaw and a bug, and you need a work-around. But you better do this only locally, as it introduces a security risk!
Here an excerpt from the manual of next GeigerLog 1.3:
Redirection for GMC counters
Deficiency – Port Number Problem: The firmware of a GMC counter forces the use of port=80. However, port numbers 0 … 1024 are reserved for users with Admin rights, and for security reasons it would be a bad idea to run GeigerLog as Admin, solely to open such a server port! Perhaps even in conflict with an active regular web server, which almost always also listens at port=80.
Bug – “Unsafe” Operation Problem: The GMC counter’s firmware form the URL in such a way, that modern servers reject their contact as a security issue. One can overcome this by explicitly putting an “Unsafe” into their configuration file 1). But which Web server Admin would convert their server intentionally into a security risk?
1) h**p://httpd.apache.org/docs/2.4/de/mod/core.html see HttpProtocolOptions
Then on the now unsafe server you can run PHP to handle the data as you like.
