If you have a USB connection problem
Note:
You must be registered in order to post a reply.
To register,
click here
. Registration is FREE!
640 x 480
800 x 600
1024 x 768
1280 x 1024
Basic
Help
Prompt
Format:
Font
Andale Mono
Arial
Arial Black
Book Antiqua
Century Gothic
Comic Sans MS
Courier New
Georgia
Impact
Lucida Console
Script MT Bold
Stencil
Tahoma
Times New Roman
Trebuchet MS
Verdana
Size
1
2
3
4
5
6
Color
Black
Red
Yellow
Pink
Green
Orange
Purple
Blue
Beige
Brown
Teal
Navy
Maroon
LimeGreen
Forum Code
is ON
T O P I C R E V I E W
wtfajawamnet@comcast.n
Posted - 05/04/2021 : 11:00:06
If you keep getting com errors regardless of what, open Device Manager and see what driver pops up.
I had an issue where it would call the RAMPS driver (for Matterhacker 3D Printer crap) whenever the 300 was plugged in.
I tried just uninstalling the driver from the Device Mangler but it still kept coming up as RAMPS on some COM port
So then I recalled this post
https://superuser.com/questions/1393737/how-to-completely-uninstall-usb-device-i-e-mouse-or-keyboard-driver
Where it states:
"Go to Device Manager or alternatively run the command (WindowsKey + R):
devmgmt.msc
Right-click the device you need to uninstall and go to Properties. Select the Details tab and then select INF Name from the drop-down list.
Once you have the INF Name, type in this command in a command window opened with Admin privileges:
pnputil.exe -d INFName.inf
If you face issues try forced deletion:
pnputil.exe -f -d INFName.inf
Worked. Now the GC 300 uses the correct driver. There's something wrong with the device ID that either Matterhackers or GC is using.
Generated in 0.05 sec.
