 GMC-320V5 wifi doesn't connect
wa1gon Posted - 09/28/2020 : 14:43:18
I can't get the device to connect to WiFi. I tried writing it from the logging program, but nothing works.
Suggestions
Darryl
EmfDev Posted - 03/03/2022 : 11:31:10
Hi stt, sent you an email with firmware update. Does the popup appear on your computer or on the device?
You can try to reset the WiFi module with AT+RST
stt Posted - 03/03/2022 : 01:14:08
I also have wifi problem with GMC-320+v5, from router logs I can see that for the device MAC address it keeps saying "associated" and "authenticated" and it keeps repeating those every 5sec. I tried moving closer in case it's signal level issue and also tried reseting factory settings but no change.
It is Rev 5.09 (F4xxxxxxxxxx92) could firmware upgrade help?
Thanks.
EmfDev Posted - 09/28/2020 : 14:57:05
Hi wa1gon, can I ask what seems to be the problem when connecting to the WiFi?
