| T O P I C R E V I E W |
| lyda |
Posted - 02/01/2017 : 15:34:24 I have a GMC-300E. Based on Phil Gillaspy's C++ implementation and a review of the newer data sheet, I've written a version in Go which exports out a Prometheus endpoint.
However when I look at the data block I receive from a <GETCFG>> request, there clearly is some data past byte 59.
From Phil's project there's an "External Interface Control Document" which documents the config block in detail, but it's out of date. I can't find a more recent one. I did find a more up to date GQ-RFC1201.txt document on the GQ site, but the other document doesn't seem to be anywhere.
Also I'd be interested in feedback from people with other GMC devices. I've tried to make the code play nice with other models, but only have my own to test with. It's still a work in progress but issues and merge requests are welcome. |
| ullix |
Posted - 02/15/2017 : 03:32:05 Thx. I can see the calibration Hi and Lo byte for CPM, and think this is a 16 bit unsigned Integer?
But how is the format for CalibrationuSvUcByte3 ... 1? |
| lyda |
Posted - 02/08/2017 : 05:24:00 Thanks! |
| ZLM |
Posted - 02/07/2017 : 20:14:14 CFG data Offset table. Start from 0 ========================================== PowerOnOff, //to check if the power is turned on/off intended AlarmOnOff, //1 SpeakerOnOff, GraphicModeOnOff, BackLightTimeoutSeconds, IdleTitleDisplayMode, AlarmCPMValueHiByte, //6 AlarmCPMValueLoByte, CalibrationCPMHiByte_0, CalibrationCPMLoByte_0, CalibrationuSvUcByte3_0, CalibrationuSvUcByte2_0, //11 CalibrationuSvUcByte1_0, CalibrationuSvUcByte0_0, CalibrationCPMHiByte_1, CalibrationCPMLoByte_1, //15 CalibrationuSvUcByte3_1, CalibrationuSvUcByte2_1, CalibrationuSvUcByte1_1, CalibrationuSvUcByte0_1, CalibrationCPMHiByte_2, //20 CalibrationCPMLoByte_2, CalibrationuSvUcByte3_2, CalibrationuSvUcByte2_2, CalibrationuSvUcByte1_2, CalibrationuSvUcByte0_2, //25 IdleDisplayMode, AlarmValueuSvByte3, AlarmValueuSvByte2, AlarmValueuSvByte1, AlarmValueuSvByte0, //30 AlarmType, SaveDataType, SwivelDisplay, ZoomByte3, ZoomByte2, //35 ZoomByte1, ZoomByte0, SPI_DataSaveAddress2, SPI_DataSaveAddress1, SPI_DataSaveAddress0, //40 SPI_DataReadAddress2, SPI_DataReadAddress1, SPI_DataReadAddress0, PowerSavingMode, Reserved, //45 Reserved, Reserved, DisplayContrast, MAX_CPM_HIBYTE, MAX_CPM_LOBYTE, //50 Reserved, LargeFontMode, LCDBackLightLevel, ReverseDisplayMode, MotionDetect, //55 bBatteryType, BaudRate, Reserved, GraphicDrawingMode, LEDOnOff, Reserved, SaveThresholdValueuSv_m_nCPM_HIBYTE, SaveThresholdValueuSv_m_nCPM_LOBYTE, SaveThresholdMode, SaveThresholdValue3, SaveThresholdValue2, SaveThresholdValue1, SaveThresholdValue0, Save_DateTimeStamp, //this one uses 6 byte space
