 Stange behaviour with GMC data view
sim_v Posted - 03/31/2014 : 06:58:28
Since Sunday, I got no log. GMX Data viewer export endless CVS log with strange dates. The only thing to notice is the setting of sunset time Sunday with computer synchronization (+ 1 hour).
Today, Monday, I'm reseting setting and saved Data on GMC-320+ and re-synchronize Time with computer. Set a location 'A' and dumped data after some minutes (2014-03-31 15:50 local time)
Export to CSV continue to give strange date & time.
GQ Electronics LLC, GMC-300 Data Viewer,Version 2.07
Date Time,Data Type,CPM,#1,#2,#3,#4,#5,#6,#7,#8,#9,#10,#11,#12,#13,#14,#15,#16,#17,#18,#19,#20,#21,#22,#23,#24,#25,#26,#27,#28,#29,#30,#31,#32,#33,#34,#35,#36,#37,#38,#39,#40,#41,#42,#43,#44,#45,#46,#47,#48,#49,#50,#51,#52,#53,#54,#55,#56,#57,#58,#59,#60,
2014-03-00 00:00,Every Second,23,0,0,0,0,0,0,0,0,1,0,1,0,0,0,1,1,0,0,2,0,0,0,0,0,0,0,0,1,1,1,0,0,1,1,0,1,1,0,0,0,1,0,0,1,0,0,0,0,1,0,2,2,0,1,0,1,0,0,1,0,
2014-03-00 00:01,Every Second,11,1,0,0,0,0,0,0,0,0,0,0,0,0,1,0,1,0,0,0,0,0,0,1,0,0,1,1,0,1,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,1,1,0,0,0,0,
2014-03-00 00:02,Every Second,21,0,0,0,1,0,0,1,0,0,0,3,1,0,2,0,1,2,1,0,1,0,0,1,0,0,1,0,0,1,0,1,0,0,0,1,1,0,0,0,0,2,0,
A,,,
2014-03-00 00:02,Every Second,5,0,0,0,0,2,1,0,0,0,0,0,0,0,0,1,1,0,
A,,,
2014-03-00 00:02,Every Second,9,1,0,4,0,0,1,1,0,0,1,0,1,0,0,
2014-03-00 00:02,Every Second,20,0,0,0,0,0,0,0,0,1,0,0,0,1,0,0,2,0,0,0,0,0,1,1,1,0,1,1,0,1,0,0,0,0,0,1,0,0,0,1,2,2,0,0,1,0,1,0,1,0,0,0,0,0,0,0,0,0,0,1,0,
2014-03-00 00:03,Every Second,20,1,0,0,0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,1,1,0,0,0,0,0,0,0,1,0,0,0,0,0,3,1,0,2,0,2,1,0,1,0,1,0,1,0,1,0,
2014-03-00 00:04,Every Second,5,1,0,0,0,1,1,0,0,0,0,2,0,
A,,,
ZLM Posted - 04/01/2014 : 20:26:52
sim_v: can you send your .bin file to me? support@gqelectronicsllc.com
then I can check it for you.
sim_v Posted - 04/01/2014 : 12:15:52
ZLM: My unit displays date & time correctly.
Only CSV export seems to be incorrect.
ZLM Posted - 04/01/2014 : 12:00:23
sim_v:
it seems your unit Time and Date is not been set correctly. Make sure your unit has correct Date and Time.
kb:
If the data recording reached to the size of flash memory, then it will go back to the beginning of the memory. This will erase the part of the old data sector by sector. Until reach to the size of flash memory again. In this case, if you download the data, you will see start at the latest data, and then suddenly changes to old data. This may let you confuse.
To get better boundary of the data history, I think the best way is to erase the old data before to start new recording session.
kb Posted - 03/31/2014 : 13:27:28
I noticed I have very strange data outputs also, very unreliable and random.
Sometimes it will record 10 days of data, saving every minute, other times only a few days.
I also have a mazur prm9000, harder unit to use and to download the data but its all there.
