 Graphics display moved in software
kukulcan Posted - 01/08/2013 : 11:02:12
Dear readers,
First I like the GMC-300, its easy to use.e
I am having some problem with the software, the graphic display part is not aligned within its borders. Its in both the viewer and logger.
I am running Windows 8Pro and tried it in XP compatibility mode but it doesn't change anything to the graphics make up.
71.13 KB
I am having around 25+ CPM readings in the house here in South-India and around 10+ outside. Is the difference possible because these houses made of a locally backed red mud brick polluted with cadmium and whatever more. Is this cadmium radioactive or is this reading normal inside a house?
Thanks for your effort.
kukulcan Posted - 01/09/2013 : 00:29:24
A found it, because its a tablet everything on the desktop gets enlarged/optimized for touch. I put it back to 100% and now the graph is in it place again.
My apologies ZLM for making this a topic, please delete the thread.
ZLM Posted - 01/08/2013 : 23:34:33
Did you use any special Windows font size? try to use default and see if it changes any thing.
ZLM Posted - 01/08/2013 : 19:20:07
around 25+ CPM is normal.
