 Installing GeigerLog on Mac
Opsimath Posted - 11/15/2024 : 15:23:15
I the new owner of a GMC-800 and I want to use the software GeigerLog. I installed Python3 with no issues. When I run ./GeigerLog.sh setup, I get errors and warnings. I'm have a MacBook Pro running Sequoia 15.0.1. Can anyone help? Here is the output.
m@Marcos-MacBook-Pro geigerlog % ./GeigerLog.sh setup
############################################ GeigerLog Startup #############################################
Checking for Working Directory
Current Directory: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog
Found file 'geigerlog.py'; taking this as GeigerLog working directory!
Checking for Virtual Environment
GeigerLog Auto-Setup
A Virtual Environment does exist as '__venvGL1_5_0'.
Using Virtual Environment '__venvGL1_5_0'
Checking for computer type
This is a Mac computer
Checking System
Computer type: Mac
Python version: 3.13.0
Python executable: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3
Virtual Environment: Yes, running within venv: '__venvGL1_5_0'
sys.base_prefix: /Library/Frameworks/Python.framework/Versions/3.13
sys.prefix: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0
Updating modules 'Pip' and 'setuptools' to their latest version
Module Status:
Module: pip
Installing with Command: ['/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3', '-m', 'pip', 'install', '-U', 'pip']
: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 -m pip install -U pip
pipout: Requirement already satisfied: pip in ./__venvGL1_5_0/lib/python3.13/site-packages (24.3.1)
pipout:
Sussessful
Module: setuptools
Installing with Command: ['/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3', '-m', 'pip', 'install', '-U', 'setuptools']
: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 -m pip install -U setuptools
pipout: Requirement already satisfied: setuptools in ./__venvGL1_5_0/lib/python3.13/site-packages (75.5.0)
pipout:
Sussessful
Checking Module Installation:
Module Status:
Module: pip Installed Version: 24.3.1 Min Version: 23.3.2 : Ok
Module: setuptools Installed Version: 75.5.0 Min Version: 69.0.3 : Ok
Module: PyQt5 Installed Version: None Min Version: 5.15.2 : MISSING
Module: PyQt5-sip Installed Version: None Min Version: 12.8.1 : MISSING
Module: matplotlib Installed Version: None Min Version: 3.8.3 : MISSING
Module: numpy Installed Version: None Min Version: 1.26.2 : MISSING
Module: scipy Installed Version: None Min Version: 1.10.1 : MISSING
Module: soundfile Installed Version: 0.12.1 Min Version: 0.12.1 : Ok
Module: sounddevice Installed Version: 0.4.6 Min Version: 0.4.6 : Ok
Module: pyserial Installed Version: 3.5 Min Version: 3.5 : Ok
Module: paho-mqtt Installed Version: 1.6.1 Min Version: 1.6.1 : Ok
Module: psutil Installed Version: None Min Version: 5.8.0 : MISSING
Module: ntplib Installed Version: 0.3.4 Min Version: 0.3.4 : Ok
Module: py-cpuinfo Installed Version: 9.0.0 Min Version: 9.0.0 : Ok
Module: bmm150 Installed Version: 0.2.2 Min Version: 0.2.2 : Ok
Module: LabJackPython Installed Version: 2.1.0 Min Version: 2.1.0 : Ok
Module: pip-check Installed Version: 2.8.1 Min Version: 2.8.1 : Ok
Some modules need installation or update:
Module: PyQt5 Forcing Version: 5.15.2
Installing with Command: ['/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3', '-m', 'pip', 'install', 'PyQt5==5.15.2']
: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 -m pip install PyQt5==5.15.2
pipout: Collecting PyQt5==5.15.2
pipout: Using cached PyQt5-5.15.2.tar.gz (3.3 MB)
pipout: Installing build dependencies: started
pipout: Installing build dependencies: finished with status 'done'
pipout: Getting requirements to build wheel: started
pipout: Getting requirements to build wheel: finished with status 'done'
pipout: Preparing metadata (pyproject.toml): started
pipout: Preparing metadata (pyproject.toml): finished with status 'error'
pipout:
ERROR or WARNING on pip-install
piperr: error: subprocess-exited-with-error
piperr:
piperr: × Preparing metadata (pyproject.toml) did not run successfully.
piperr: #9474; exit code: 1
piperr: #9584;#9472;> [32 lines of output]
piperr: pyproject.toml: line 7: using '[tool.sip.metadata]' to specify the project metadata is deprecated and will be removed in SIP v7.0.0, use '[project]' instead
piperr: Traceback (most recent call last):
piperr: File "/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
piperr: main()
piperr: ~~~~^^
piperr: File "/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
piperr: json_out['return_val'] = hook(**hook_input['kwargs'])
piperr: ~~~~^^^^^^^^^^^^^^^^^^^^^^^^
piperr: File "/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 152, in prepare_metadata_for_build_wheel
piperr: whl_basename = backend.build_wheel(metadata_directory, config_settings)
piperr: File "/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-build-env-tmwyyc2w/overlay/lib/python3.13/site-packages/sipbuild/api.py", line 28, in build_wheel
piperr: project = AbstractProject.bootstrap('wheel',
piperr: arguments=_convert_config_settings(config_settings))
piperr: File "/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-build-env-tmwyyc2w/overlay/lib/python3.13/site-packages/sipbuild/abstract_project.py", line 74, in bootstrap
piperr: project.setup(pyproject, tool, tool_description)
piperr: ~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
piperr: File "/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-build-env-tmwyyc2w/overlay/lib/python3.13/site-packages/sipbuild/project.py", line 608, in setup
piperr: self.apply_user_defaults(tool)
piperr: ~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^
piperr: File "/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-vf0et_6x/pyqt5_728ede7303d14642a618c11e695082c9/project.py", line 63, in apply_user_defaults
piperr: super().apply_user_defaults(tool)
piperr: ~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^
piperr: File "/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-build-env-tmwyyc2w/overlay/lib/python3.13/site-packages/pyqtbuild/project.py", line 51, in apply_user_defaults
piperr: File "/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-build-env-tmwyyc2w/overlay/lib/python3.13/site-packages/sipbuild/project.py", line 237, in apply_user_defaults
piperr: self.builder.apply_user_defaults(tool)
piperr: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^
piperr: File "/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-build-env-tmwyyc2w/overlay/lib/python3.13/site-packages/pyqtbuild/builder.py", line 50, in apply_user_defaults
piperr: raise PyProjectOptionException('qmake',
piperr: "specify a working qmake or add it to PATH")
piperr: sipbuild.pyproject.PyProjectOptionException
piperr: [end of output]
piperr:
piperr: note: This error originates from a subprocess, and is likely not a problem with pip.
piperr: error: metadata-generation-failed
piperr:
piperr: × Encountered error while generating package metadata.
piperr: #9584;#9472;> See above for output.
piperr:
piperr: note: This is an issue with the package mentioned above, not pip.
piperr: hint: See above for details.
piperr:
FAILURE
Module: PyQt5-sip Forcing Version: 12.8.1
Installing with Command: ['/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3', '-m', 'pip', 'install', 'PyQt5-sip==12.8.1']
: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 -m pip install PyQt5-sip==12.8.1
pipout: Collecting PyQt5-sip==12.8.1
pipout: Using cached PyQt5_sip-12.8.1.tar.gz (102 kB)
pipout: Preparing metadata (pyproject.toml): finished with status 'done'
pipout: Building wheels for collected packages: PyQt5-sip
pipout: Building wheel for PyQt5-sip (pyproject.toml): started
pipout: Building wheel for PyQt5-sip (pyproject.toml): finished with status 'error'
pipout: Failed to build PyQt5-sip
pipout:
piperr:
piperr: × Building wheel for PyQt5-sip (pyproject.toml) did not run successfully.
piperr: #9584;#9472;> [10 lines of output]
piperr: running bdist_wheel
piperr: running build
piperr: running build_ext
piperr: building 'PyQt5.sip' extension
piperr: creating build/temp.macosx-10.13-universal2-cpython-313
piperr: clang -fno-strict-overflow -Wsign-compare -Wunreachable-code -fno-common -dynamic -DNDEBUG -g -O3 -Wall -arch arm64 -arch x86_64 -I/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/include -I/Library/Frameworks/Python.framework/Versions/3.13/include/python3.13 -c apiversions.c -o build/temp.macosx-10.13-universal2-cpython-313/apiversions.o
piperr: xcode-select: note: No developer tools were found, requesting install.
piperr: If developer tools are located at a non-default location on disk, use `sudo xcode-select --switch path/to/Xcode.app` to specify the Xcode that you wish to use for command line developer tools, and cancel the installation dialog.
piperr: See `man xcode-select` for more details.
piperr: error: command '/usr/bin/clang' failed with exit code 1
piperr:
piperr: ERROR: Failed building wheel for PyQt5-sip
piperr: ERROR: ERROR: Failed to build installable wheels for some pyproject.toml based projects (PyQt5-sip)
piperr:
FAILURE
Module: matplotlib Forcing Version: 3.8.3
Installing with Command: ['/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3', '-m', 'pip', 'install', 'matplotlib==3.8.3']
: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 -m pip install matplotlib==3.8.3
pipout: Collecting matplotlib==3.8.3
pipout: Using cached matplotlib-3.8.3.tar.gz (35.9 MB)
pipout: Collecting contourpy>=1.0.1 (from matplotlib==3.8.3)
pipout: Using cached contourpy-1.3.1-cp313-cp313-macosx_11_0_arm64.whl.metadata (5.4 kB)
pipout: Collecting cycler>=0.10 (from matplotlib==3.8.3)
pipout: Using cached cycler-0.12.1-py3-none-any.whl.metadata (3.8 kB)
pipout: Collecting fonttools>=4.22.0 (from matplotlib==3.8.3)
pipout: Using cached fonttools-4.55.0-cp313-cp313-macosx_10_13_universal2.whl.metadata (164 kB)
pipout: Collecting kiwisolver>=1.3.1 (from matplotlib==3.8.3)
pipout: Using cached kiwisolver-1.4.7-cp313-cp313-macosx_11_0_arm64.whl.metadata (6.3 kB)
pipout: Collecting numpy<2,>=1.21 (from matplotlib==3.8.3)
pipout: Using cached numpy-1.26.4.tar.gz (15.8 MB)
pipout: Installing backend dependencies: started
pipout: Installing backend dependencies: finished with status 'done'
pipout:
piperr:
piperr: #9584;#9472;> [17 lines of output]
piperr: + /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-gvft8_bx/numpy_b7efcab1fbcd4395a3a045a91e6ecbbc/vendored-meson/meson/meson.py setup /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-gvft8_bx/numpy_b7efcab1fbcd4395a3a045a91e6ecbbc /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-gvft8_bx/numpy_b7efcab1fbcd4395a3a045a91e6ecbbc/.mesonpy-34p0otwj -Dbuildtype=release -Db_ndebug=if-release -Db_vscrt=md --native-file=/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-gvft8_bx/numpy_b7efcab1fbcd4395a3a045a91e6ecbbc/.mesonpy-34p0otwj/meson-python-native-file.ini
piperr: The Meson build system
piperr: Version: 1.2.99
piperr: Source dir: /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-gvft8_bx/numpy_b7efcab1fbcd4395a3a045a91e6ecbbc
piperr: Build dir: /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-gvft8_bx/numpy_b7efcab1fbcd4395a3a045a91e6ecbbc/.mesonpy-34p0otwj
piperr: Build type: native build
piperr: Project name: NumPy
piperr: Project version: 1.26.4
piperr:
piperr: ../meson.build:1:0: ERROR: Unknown compiler(s): [['cc'], ['gcc'], ['clang'], ['nvc'], ['pgcc'], ['icc'], ['icx']]
piperr: The following exception(s) were encountered:
piperr: Running `nvc --version` gave "[Errno 2] No such file or directory: 'nvc'"
piperr: Running `pgcc --version` gave "[Errno 2] No such file or directory: 'pgcc'"
piperr: Running `icc --version` gave "[Errno 2] No such file or directory: 'icc'"
piperr: Running `icx --version` gave "[Errno 2] No such file or directory: 'icx'"
piperr:
piperr: A full log can be found at /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-gvft8_bx/numpy_b7efcab1fbcd4395a3a045a91e6ecbbc/.mesonpy-34p0otwj/meson-logs/meson-log.txt
piperr:
piperr:
piperr:
piperr:
FAILURE
Module: numpy Forcing Version: 1.26.2
Installing with Command: ['/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3', '-m', 'pip', 'install', 'numpy==1.26.2']
: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 -m pip install numpy==1.26.2
pipout: Collecting numpy==1.26.2
pipout: Using cached numpy-1.26.2.tar.gz (15.7 MB)
pipout:
piperr:
piperr: + /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-y8xolpda/numpy_3cc7d61b3c7847129cc6bf89a98039b9/vendored-meson/meson/meson.py setup /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-y8xolpda/numpy_3cc7d61b3c7847129cc6bf89a98039b9 /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-y8xolpda/numpy_3cc7d61b3c7847129cc6bf89a98039b9/.mesonpy-sgkmvz58/build -Dbuildtype=release -Db_ndebug=if-release -Db_vscrt=md --native-file=/private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-y8xolpda/numpy_3cc7d61b3c7847129cc6bf89a98039b9/.mesonpy-sgkmvz58/build/meson-python-native-file.ini
piperr: Source dir: /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-y8xolpda/numpy_3cc7d61b3c7847129cc6bf89a98039b9
piperr: Build dir: /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-y8xolpda/numpy_3cc7d61b3c7847129cc6bf89a98039b9/.mesonpy-sgkmvz58/build
piperr: Project version: 1.26.2
piperr:
piperr: ../../meson.build:1:0: ERROR: Unknown compiler(s): [['cc'], ['gcc'], ['clang'], ['nvc'], ['pgcc'], ['icc'], ['icx']]
piperr:
piperr: A full log can be found at /private/var/folders/62/pjnc78m1081772wcnld1hhb40000gn/T/pip-install-y8xolpda/numpy_3cc7d61b3c7847129cc6bf89a98039b9/.mesonpy-sgkmvz58/build/meson-logs/meson-log.txt
piperr:
piperr:
piperr:
piperr:
FAILURE
Module: scipy Forcing Version: 1.10.1
Installing with Command: ['/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3', '-m', 'pip', 'install', 'scipy==1.10.1']
: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 -m pip install scipy==1.10.1
pipout:
piperr: ERROR: Ignored the following yanked versions: 1.14.0rc1
piperr: ERROR: Ignored the following versions that require a different python version: 1.10.0 Requires-Python <3.12,>=3.8; 1.10.0rc1 Requires-Python <3.12,>=3.8; 1.10.0rc2 Requires-Python <3.12,>=3.8; 1.10.1 Requires-Python <3.12,>=3.8; 1.11.0 Requires-Python <3.13,>=3.9; 1.11.0rc1 Requires-Python <3.13,>=3.9; 1.11.0rc2 Requires-Python <3.13,>=3.9; 1.11.1 Requires-Python <3.13,>=3.9; 1.11.2 Requires-Python <3.13,>=3.9; 1.11.3 Requires-Python <3.13,>=3.9; 1.6.2 Requires-Python >=3.7,<3.10; 1.6.3 Requires-Python >=3.7,<3.10; 1.7.0 Requires-Python >=3.7,<3.10; 1.7.1 Requires-Python >=3.7,<3.10; 1.7.2 Requires-Python >=3.7,<3.11; 1.7.3 Requires-Python >=3.7,<3.11; 1.8.0 Requires-Python >=3.8,<3.11; 1.8.0rc1 Requires-Python >=3.8,<3.11; 1.8.0rc2 Requires-Python >=3.8,<3.11; 1.8.0rc3 Requires-Python >=3.8,<3.11; 1.8.0rc4 Requires-Python >=3.8,<3.11; 1.8.1 Requires-Python >=3.8,<3.11; 1.9.0 Requires-Python >=3.8,<3.12; 1.9.0rc1 Requires-Python >=3.8,<3.12; 1.9.0rc2 Requires-Python >=3.8,<3.12; 1.9.0rc3 Requires-Python >=3.8,<3.12; 1.9.1 Requires-Python >=3.8,<3.12
piperr: ERROR: Could not find a version that satisfies the requirement scipy==1.10.1 (from versions: 0.8.0, 0.9.0, 0.10.0, 0.10.1, 0.11.0, 0.12.0, 0.12.1, 0.13.0, 0.13.1, 0.13.2, 0.13.3, 0.14.0, 0.14.1, 0.15.0, 0.15.1, 0.16.0, 0.16.1, 0.17.0, 0.17.1, 0.18.0, 0.18.1, 0.19.0, 0.19.1, 1.0.0, 1.0.1, 1.1.0, 1.2.0, 1.2.1, 1.2.2, 1.2.3, 1.3.0, 1.3.1, 1.3.2, 1.3.3, 1.4.0, 1.4.1, 1.5.0, 1.5.1, 1.5.2, 1.5.3, 1.5.4, 1.6.0, 1.6.1, 1.9.2, 1.9.3, 1.11.4, 1.12.0rc1, 1.12.0rc2, 1.12.0, 1.13.0rc1, 1.13.0, 1.13.1, 1.14.0rc2, 1.14.0, 1.14.1)
piperr: ERROR: No matching distribution found for scipy==1.10.1
piperr:
FAILURE
Module: psutil Forcing Version: 5.8.0
Installing with Command: ['/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3', '-m', 'pip', 'install', 'psutil==5.8.0']
: /Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/bin/python3 -m pip install psutil==5.8.0
pipout: Collecting psutil==5.8.0
pipout: Using cached psutil-5.8.0.tar.gz (470 kB)
pipout: Building wheels for collected packages: psutil
pipout: Building wheel for psutil (pyproject.toml): started
pipout: Building wheel for psutil (pyproject.toml): finished with status 'error'
pipout: Failed to build psutil
pipout:
piperr:
piperr: × Building wheel for psutil (pyproject.toml) did not run successfully.
piperr: #9584;#9472;> [42 lines of output]
piperr: running build_py
piperr: creating build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_pswindows.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_common.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/__init__.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_psosx.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_psbsd.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_psaix.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_pslinux.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_compat.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_psposix.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: copying psutil/_pssunos.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil
piperr: creating build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_contracts.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_connections.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/runner.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_unicode.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_misc.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_posix.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_linux.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_sunos.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/__init__.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_aix.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_process.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_bsd.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_system.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_osx.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_memleaks.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_windows.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/__main__.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: copying psutil/tests/test_testutils.py -> build/lib.macosx-10.13-universal2-cpython-313/psutil/tests
piperr: building 'psutil._psutil_osx' extension
piperr: creating build/temp.macosx-10.13-universal2-cpython-313/psutil
piperr: creating build/temp.macosx-10.13-universal2-cpython-313/psutil/arch/osx
piperr: clang -fno-strict-overflow -Wsign-compare -Wunreachable-code -fno-common -dynamic -DNDEBUG -g -O3 -Wall -arch arm64 -arch x86_64 -DPSUTIL_POSIX=1 -DPSUTIL_SIZEOF_PID_T=4 -DPSUTIL_VERSION=580 -DPSUTIL_OSX=1 -I/Users/m/Downloads/geigerlog-v1.5.0/geigerlog/__venvGL1_5_0/include -I/Library/Frameworks/Python.framework/Versions/3.13/include/python3.13 -c psutil/_psutil_common.c -o build/temp.macosx-10.13-universal2-cpython-313/psutil/_psutil_common.o
piperr:
piperr: ERROR: Failed building wheel for psutil
piperr: ERROR: ERROR: Failed to build installable wheels for some pyproject.toml based projects (psutil)
piperr:
FAILURE
Installation or update had errors; cannot continue!
Please, verify installation manually.
This GeigerLog tool 'PipCheck.sh' or 'PipCheck.bat' may be of help.
EmfDev Posted - 11/19/2024 : 17:57:48
I also had issues with the Geigerlog V1.5. Try to use V1.4
Opsimath Posted - 11/16/2024 : 06:43:43
First and foremost, thank you for the prompt reply and I am grateful that such a software tool is made available for public use.
I will do as you suggest and respond with the results. Thank you again.
ullix Posted - 11/15/2024 : 23:45:30
@Opsimath:
I suggest to download the latest development version of GeigerLog from this site:
https://sourceforge.net/p/geigerlog/discussion/devel2/
As of today this version is pre16, but use whatever the latest is.
If this still does not work, then file a ticket at
https://sourceforge.net/p/geigerlog/tickets/
Attach any output as text files.
Generated in 0.24 sec. Snitz's Forums 2000
