| T O P I C R E V I E W |
| sebastian |
Posted - 02/09/2024 : 15:42:02 The only trouble I have with my 500+ is that the date/time of the unit shifts significantly after, say, a week or so. Will be very helpful if it can synchronize its clock with a network time server. It¡¦s not connected to PC, have to set the clock manual from time to time, and the log timestamp interval will be shortened or lengthened at the re-synchronization. |
| 5 L A T E S T R E P L I E S (Newest First) |
| 3z_phoenix |
Posted - 09/22/2025 : 11:52:19 only my idea here, sure it will also have Pro and Cons.
some weeks ago, on stackoverflow, i read about: "Right way to get Web Server time and display it on Web Pages" also with some code-sniplets... https://stackoverflow.com/questions/20269657/right-way-to-get-web-server-time-and-display-it-on-web-pages
maybe thats a more easy way to catch the timestring from webserver after update the counting data to www.gmcmap.com, and set the local clock. This not need to implement NTP for timesync, which i think that is much more complex. It would be usefull for standalone counters with WIFI-connection.
Cons could be its more traffic/ consuming more CPU but maybe an interval after every 10th counting-update would be right in comfort.
What do you think about this?
kind regards, 3z_phoenix
| EmfDev |
Posted - 04/15/2024 : 09:51:24 Out team is working on making the clock better. |
| the_mike |
Posted - 04/15/2024 : 08:17:07 Since the clock-issue seems to be a problem for all GMC, i'd suggest to simply add a little RealTime-Clock to the board. would be a lesser drain on the battery than a wlan-connection and an NTP-sync which, due to the current lack of an RTC will go out of sync in no time (pun intented)... |
| Bobakman |
Posted - 02/14/2024 : 20:57:06 Same with my 600+ the clock is horrible at keeping correct time. I hope a fix such as you suggested is soon to be released in the next firmware update if it can. Otherwise I love GeigerLog since it has a feature to sync the GMC Geiger counter clock to the PC time while using the program, a must when working with the data, which GeigerLog excels at hands down. Bob |
| EmfDev |
Posted - 02/12/2024 : 10:49:29 @sebastian, we are working on making the clock stable and your suggestion is actually really good. I will pass it to our team. |
