 USB driver
stefaan369twj Posted - 02/04/2023 : 14:12:19
Hi, Just bought a GMC-500.
The USB driver don't install with windows 11.
When do you plan to make tour devices compatible with windows 11?
Thanks!
Stefaan
EmfDev Posted - 02/06/2023 : 11:20:22
Hi Stefaan, Windows 10/11 usually comes with pre-installed CH-340 driver for GMC-500 Plus so you do not need to install. If you have tried to install it and it did not work, please uninstall the driver then when you plug in the device, go to device manager to find an unknown device, right click and update the driver.
ihab17 Posted - 02/05/2023 : 23:37:44
Thanks!
Stefaan
Try the following... From the command line with administrative access (run as Administrator even though you are an administrator), run the following:
bcdedit.exe /set nointegritychecks on
Retry the driver installation
If the installation goes fine, you can bring it back to the original state without affecting the already installed drivers by running:
bcdedit.exe /set nointegritychecks off
